StirCrazy
Mar 24, 2021Moderator
time2roll wrote:
The middle charge voltages in LFP are so flat it might be hard to impossible to really know on voltage alone what the charge level is. Generally a capacity test will be run top knee to bottom knee. The whole 50% discharged thing kind of fades away with LFP. It appears to me the charge level indicated by the BMS becomes more important.
it is flater than a normal battery but not that flat, you just need a better resolution voltage meter. every 0.1 seams to be aproximatly 10% so a reading of 0.01 change would be 1%. seams you can get pretty accurate with a deicent meter that is made for Li.
Steve
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
