full_mosey
Mar 24, 2021Explorer
BFL13 wrote:
But resting full is 13.6v so 100 x 13.6 =1360 watt hrs so it is confusing? Whatever, Battle Born claims the 100AH batt has "2 to 3 times the power of the same size lead acid" batt.
"Power" meaning watts? Watt hrs? meanwhile a 100 AH 12v FLA has a resting voltage of 12.73 when full so that is 1273 watt hrs.
Beats me how 1360 is 2 to 3 times 1273. I am told this would all make sense if only I owned LFPs myself, but do you need some kind of New Math too? :)
Easy, Watt-hours are energy, not power.
Which one can produce all of its energy, 100Ah, in the shortest time?
Put another way, LFP has the same size fuel tank but more horsepower and can work faster.
If the FLA is pushed to work faster than 5A, less work gets done. The LFP doesn't care because there is virtually no sliding scale of work produced based on how slow or fast it gets done.
HTH;
John
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
