time2roll
Mar 28, 2021Nomad
StirCrazy wrote:Individual prismatic cells shaping from CN
which brand did you buy? evey raw cell I have looked at say it can handle 1C all day long and maintain the 3000 to 4500 cycles its rated at, the optimal 0.2C and such will get you around 7000 cycles.
Steve
Steve
Note here constant current is listed twice. Specs do not always translate well.
ange of application
Product name: lithium iron phosphate cell
Shell Material: Aluminum
Nominal capacity: 310Ah
Minimum capacity: 310Ah
Internal impedance: 0.1 ~ 0.3m?
Nominal voltage: 3.2V
Discharge end voltage: 2.5 v
Recommend constant current: 310a (1c)
Recommend constant current: 155a (0.5c)
Charging voltage: 3.65 v
Maximum continuous discharge current: 310a (1c)
Life cycle (80% dod): 4000 cycles
Charging temperature: -5 60 60 ° c
Discharge temperature: -30 60 60 ° c
Dimensions (l*w*h): 211*170*70mm
