theoldwizard1
Sep 14, 2020Explorer II
MrWizard wrote:
Lithium has it's Quirks !
Do Not leave the battery connected while stored aka Not Camping
A drop in (lithium) battery with built in BMS should be ok connected to shore power while camping
The info from the (battery) Mfg should specify how and when
Concur ! A BMS (typically built in) is critical !
If the maximum voltage your converter can output is 13.8V, this may not be adequate. Check with the battery/BMS manufacturer !
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
