pianotuna wrote:
msmith1199 wrote:
What is the advantage to them over Lithium? Is it just cost? Do they provide as much power?
As far as power goes 100 amp-hours is 100 amp-hours. However SiO2 may do larger discharge rates than LI. LI appear to be limited to about 1 C.
Similar to LI in that partial charging is just fine--though best practise is to do a full charge on a monthly basis.
advantages
1. can be used and charged at -40
2. can be run stone bone dead 620 times
3. can do 50% discharge 2800 times
4. no need to stop charging at 90% which LI prefer (for storage)
5. can do 80% discharge 1500 times
disadvantages:
1. heavier and larger foot print than Li
2. charge rate 4/c however if one has 300 amp-hours that hardly matters as convert size may not be able to get to 75 amps--without upgrading.
In addition to the silicon dioxide battery characteristics that Don lists above, they have one more advantage over lithium batteries that is important to me:
Lithium RV batteries hold their output voltage "high" right to the end before recharging ... their output voltage does not taper off a bit as they discharge .... unlike what the output voltage of lead acid batteries and that of silicon dioxide batteries does. To me the output not tapering off - like lithiums do - as they discharge IS NOT preferred ... it's a "disadvantage". It's nice to know when you're getting near the point where recharging is necessary by merely periodically checking the voltage on your RV's battery powered circuit - when that voltage reads around 12 volts, recharge them. As I understand it, silicon dioxide RV batteries act about the same way ... making it very simple to know about when to recharge them.
To get around this when switching to lithium RV batteries - in addition to their higher cost - you must spend even more money on what is technically known as an "integrating ammeter". This is a battery monitor that tracks how many amps are removed from the battery bank over time - thus showing how many amp hours have been used out of the battery bank.
To me, the above is just another gadget to buy in addition to the high lithium battery initial cost. Why have to purchase an amp hour consumption monitor - when silicon dioxide RV batteries have just about the same performance characteristics (they weigh more than lithium, but they recharge and operate at lower temperatures than lithium) as lithium RV batteries.
P.S. For example, I have a lot of lithium battery powered flashlights, remotes, and small tools ... AND IT'S VERY IRRITATING when they surprise you by suddenly dying with very little get-dim/slow-down type discharged warnings.
