Ivylog
Nov 15, 2021Explorer III
“I need to use the battery combiner dash switch to start the engine.” Because of the higher voltage I would hold the boost switch down for a minute to charge the engine batteries so even though the Lithium’s BMS will only give you 100 amps, the higher voltage should make the difference.
