Itinerant1
Dec 22, 2018Explorer
Insulate the box and add a reptile style heat pad or move the batteries to a better protected area.
With my lfp in the front compartment of the 5th wheel I added 2" foam insulation on the walls, plus the inverter in that compartment helps with a small amount of heat. At 25f outside temp it was 40s in the compartment and the batteries were 5+ degrees warmer.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
