pianotuna
May 08, 2021Nomad III
Slownsy wrote:
And would really like to understand how if possible for batteries to draw that much A true a small wire. Also Renogy recommendations for power to there dc to dc chargers are rather large for a long run. I do actually have 00 cable from batteries to rear drawbar but that is for my winch.
Thanks Frank.
It is more about getting a constant voltage to the Li Batteries.
My OEM charging was fused at 60 amps. I did blow the fuse 3 times before I replaced it with an auto reset 50 amp breaker. I did double up on the charging path and have seen over 70 amps (How much over I do not know as my ammeter stops at 70 and starts flashing).
