BFL13
May 09, 2021Explorer II
-The base alternator is still a 157A single unit on the 6.7L.
-Extra Heavy Duty Alternator (220A single unit) is the first possible upgrade:
Required on any truck with the snowplow package
Required on any Lariat and up trim truck with the upfitter switches OR 110v outlet
Required on any XL or XLT truck with the upfitter switches and 110v outlet ordered together
https://www.ford-trucks.com/forums/1503981-2017-alternator-questions-dual-single-extra-heavy-duty-soo-on.html
AFAIK, if your LFPs want more amps than what the 7-pin can supply it will just blow the fuse on the pin # 4 wire.
Not clear what you really want for a set-up here. Once that is clear , there will be a number of ways to do it.
