Slownsy
May 10, 2021Explorer
Thanks all, BFL13 thanks I take it you are referring to the wire as 4 gage on plug? Or the nor 4 position. And that this is connected true a 30A fuse that will blow if to large a drain is put on it, that was my thought also, so the lithium batteries will not smoke the alternator and only have to get dc to dc charger if I want higher charging? I have already in the past had to replace a glass fuse in FW a couple of times in the past, I think it was on the supply coming from truck, will check it and it’s rating out.
Frank.
Frank.
