time2roll
Apr 21, 2017Nomad
Wikel wrote:I do value this part of the controls and at the same time the cut off at 10 volts and 15 volts would do a little better IMO to not torture the battery at top or bottom of the capacity.
Couple hundred dollars to protect a couple thousand dollars in equipment but also helps make sure the cycle count doesn't take a hit.
