Thanks again. Curious about the 65a protector--does that not limit your inverter usage?
EDIT-- I mean the load one. The other one just shuts off the charger.
One of the Li selling points is the high amp draw allowance such as when running a microwave with a smaller AH bank than is required for lead acid batts.
Actually I am not clear on that high draw allowance. Is it just from the small voltage drop with Li so the inverter low voltage alarm does not get triggered, or is it from a higher discharge allowance without damaging the battery, or some of each?
With a smaller RV where battery bank weight matters and you choose Li to beat that, you might still want to run the MW from an inverter.
