S_Davis
Dec 07, 2022Explorer
pianotuna wrote:
S Davis,
I got the figures from the wobbly wide web. If I were going Li I'd go 40% to 85%. I never will due to cold.
Your document is too blurry for me to read.
Ok well I have read just about every spec sheet for the currently available LifeP04 cells and have never seen that in any of them, all their definitions of a battery cycle are from full charge to 2.5 volt cutoff at the stated amount of cycles.
Do you have any spec sheets that say that? If not you are giving out false info. You can use 100% of the stated capacity and still get the rated cycles according to the manufacturers of the cells.
I will try and get a better screen shot, this might be a little better.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
