S_Davis
Dec 08, 2022Explorer
profdant139 wrote:
Mordecai, what do you use to monitor whether you are short amps? (Different from a short circus, I think.). ;)
No, seriously, which device will give you an accurate picture of the remaining battery capacity? Using a cheap multimeter, I often check the voltage on my lead acid batteries, on the theory that any reading below 12.1 means that I've got a state of charge less than 50%.
But with lithium batteries, the voltage does not drop, I think. The battery goes from "full" to "dead," if I remember correctly.
Full charge is about 13.4 volts, at 12 volts you are at about 10% charge with LifeP04. Voltage does drop with state of charge just not as much as lead acid.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
