StirCrazy
Dec 11, 2022Moderator
3 tons wrote:
“And by "storage," I mean "whenever I'm not actually on a camping trip, the batteries go onto the trickle charger."
LFP’s Uber low self-discharge rate makes the solution to this quandary easy…I simply added a battery ‘side’ post knife switch disconnect from Amazon which isolates the battery whenever camper is not in use…No need to keep on a trickle charger….In this way shore power (if available?) can continue to be used to operate the 12v systems via the onboard converter-charger…
I just don't plug in at home anymore and shut off my solar. no parasitic draws in my 32 yeear old camper... as long as I am under 90% I am happy for winter storage.
in the summer I turn the solar the morning before we are going camper so it is full when I leave and it can do its top ballance then I change the profile to run from 10% to 90%. I figure one top ballance for eaxh camping trip is enough.
when we upgrade I'll probably have to add somthing like that to my battery.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
