noteven
Aug 09, 2020Explorer III
pianotuna wrote:noteven wrote:
Suggest you call your battery manufacturer for advice on correct charging with low current.
My research has discovered Li-FO4 batteries can discharge and charge at high rates, are happy to sit partially charged, and are good for 3000-4000 cycles to 20-30% when operated and stored properly. It makes them particularly suited for generator and vehicle alternator charging with the right equipment.
SiO2 is also happy to not be charged. Storage time is 2 years. They require NO special equipment to charge and do not require cell balancing devices. Maximum discharge rate is 9 C. 1/3 the price of Lifepo4
Silicon dioxide looks better suited to the pummeling by the western Canadian climate.
Having RV issues? Connect with others who have been in your shoes.24,402 PostsLatest Activity: Jul 28, 2026
