pianotuna
Aug 19, 2020Nomad III
noteven wrote:
It looks like the SiO2 Grp 27 size 100ah Soneill battery has a max charge rate of 25amps
This would make them well suited to solar vs Big Amps via a generator?
Yes, but, anyone who boondocks would want more than one. I'll be planning on four--but might just jump to six, or seven. I may put one in the Chassis as well. But 4 would want 100 amps if they were hungry.
The other issue is the "big amps". So far as I am aware 100 amps @ 12 volts is about the limit for converters. So the generator would be loaded to about 1400 watts (boost mode from a 100 amp boondocker converter) maximum.
Having RV issues? Connect with others who have been in your shoes.24,402 PostsLatest Activity: Jul 28, 2026
