jaycocreek's avatar
jaycocreek
Explorer II
Aug 08, 2020
Lithium-ion and solar panel life cycles?
With a lithium-ion battery is it better to run it down or keep solar plugged in?
I have an Engel compressor refer/freezer that draws 36-37 watts when it runs..I also have a portable 100 watt solar panel that puts out on average about 65 watts..It has been as high as 81 watts if I take the time to aim it right..
My question is,when I hooked it up,it quickly charged the battery to 100% with the Engel running and then it showed 0% input from the panel for a while then back to 64-65 watts input then 0%..
Is this method better or worse for battery cycles/longevity than running the battery down then charging it?
Completely new to solar and trying the portable solar for now...So I am a solar dummy of sorts for the time being..LOL
  • Suggest you call your battery manufacturer for advice on correct charging with low current.
    My research has discovered Li-FO4 batteries can discharge and charge at high rates, are happy to sit partially charged, and are good for 3000-4000 cycles to 20-30% when operated and stored properly. It makes them particularly suited for generator and vehicle alternator charging with the right equipment.
