time2roll
Nov 06, 2021Nomad
pianotuna wrote:If you must be exact you will have a battery monitor. Nothing wrong with 10% to 90% for maximum cycles. Really not that hard to stay in that very wide middle range. If the full 100% is used periodically it will still last 3500+ cycles and that would be 10 years cycling 100% every single day.time2roll wrote:pianotuna wrote:I am not sure I understand this statement.
You can. But you won't get the same number of cycles. There are a whole bunch of hoops to jump through if that is the goal.
Charging to maybe 95% with 13.6 volts should yield more longevity in a lithium battery.
For MAXIMUM cycles charge starting at 40% and stop charging at 90%. How do you manage that with a wfco?
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
