- HMS_BeagleExplorerCan you use an LA charger for LFP? Yes... Should you? No, at least not without reservations. A well regulated charger should work, but it will depend on the BMS installed in the battery to disconnect if over voltage. That is what they are designed to do, but it is not what they were designed to do in routine charging. Also almost every LFP vendor will tell you not to float charge LFP packs. If the float charge is set low enough, it does no harm. And if you have an LFP battery bank with no BMS, the you are risking damaging the cells and possibly a nice fire.
- pianotunaNomad III
MORSNOW wrote:
Well this thread is an eye opener for me. Everything I remember reading about lithium batteries on here has been saying I need to remove the factory built in charger and install a charger designed for lithium. So now I'm seeing that is not the case, and I can just swap to lithium and keep using the factory WFCO charging system that came installed in my Wolf Creek?
You can. But you won't get the same number of cycles. There are a whole bunch of hoops to jump through if that is the goal. MORSNOW wrote:
Yes. Although I would recommend 200+ watts solar to go along with the WFCO as I would recommend for any RV camping off-grid.
I can just swap to lithium and keep using the factory WFCO charging system that came installed in my Wolf Creek?- bighatnohorseExplorer II
MORSNOW wrote:
. . . and I can just swap to lithium and keep using the factory WFCO charging system that came installed in my Wolf Creek?
Apparently so according to their website: https://wfcoelectronics.com/lithium-solutions/ - MORSNOWNavigator IIIWell this thread is an eye opener for me. Everything I remember reading about lithium batteries on here has been saying I need to remove the factory built in charger and install a charger designed for lithium. So now I'm seeing that is not the case, and I can just swap to lithium and keep using the factory WFCO charging system that came installed in my Wolf Creek?
daily double wrote:
Can you charge lithium batteries with a regular charger or do I need to buy a special charger?
What do you mean by "regular charger"?
The factory supplied solar/battery charger built into my 2021 Artic Fox will charge lithium batteries, AGM, etc.
I'm not sure about the automotive battery charger in my shop - it's pretty ancient and I would not use that without further information. - jaycocreekExplorer III agree Steve except when I got my first Lifepo4 battery I wrote the company and asked which charger will work with your lifepo4..
And this was there answer:Lynx battery wrote:
Any charger up to 40-50amps that takes either lithium or AGM Batteries.
If you are buying new, go with one with a lithium setting.
But looking at the chart above,Gel is the closest...And I have watched a couple of Will's videos on setting up your solar controller and he mentions for most the lead acid setting will work with lifepo4..Crazy huh... - StirCrazyModerator
jaycocreek wrote:
Some say lead acid, especially AGM, are close enough to there lifepo4 batteries to use,others say you must have a smart charger with a lithium setting while others say lifepo4 charger only...:B
Will Prowse says on solar settings lead acid settings are fine for most lifepo4....My battery guy said to use the AGM setting if I didn't have a lithium setting....
Confused yet...Me too...lol
everything I have read says if you dont have the Li setting to use Gel as it is close but doesnt have the things that will damage a Li like equalizationg and such, but the others will work in a pinch also
Steve - jaycocreekExplorer IIHere is an example from my Renogy solar controller and the pre-set parameters for the different 12v batteries and how close or not they are..
daily double wrote:
Standard converter works fine. Most portable chargers will work fine too as long as you stay away from equalization and recondition options. AGM or GEL settings will tend to avoid equalization.
There is no metric electricity or lithium electricity. As long as charging meets the voltage and amperage specifications the charging is fine.
Don't get all wrapped up in having to charge at 14.6 volts to fill the battery. 13.8 will fill the battery 99% just fine. Even the dreaded WFCO at 13.6 will do OK but take a bit longer. Unlike lead-acid there is no need to cram lithium 100% full. Too many procedures from lead-acid are shoved onto lithium. I would stay away from all "lithium" converters, the stock ones are better.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 11, 2026
