KD4UPL
Oct 17, 2015Explorer II
Watts are watts. Changing the voltage doesn't change the watts.
I don't think you'll find a 200 watt 12 volt panel. The largest 12v panel I've ever seen was 140 watts or so.
You could always add a second charge controller just for the 24v panel. Connect it in parallel with your current set up and everything will work fine.
Otherwise, there is no way to use all of your current panels with your current controller.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
