brulaz
Oct 17, 2015Explorer
12thgenusa wrote:
Not sure how well the power point tracking will work with the variety of panels.
This is a concern.
Rogue Manual wrote:
Although the individual PV modules of an array need not necessarily be of the same make or model, you will
achieve better tracking performance from an array in which all of the modules have the same maximum
power point (V mp ). This is best accomplished by choosing modules of the same make and model. Even if
modules are not identical, be sure that they each have the same number of cells. While it is possible to wire
modules together with varying numbers of cells, this will degrade the output of the entire array.
If you don't want to send the panel back, I would put it on the Roque and run that in parallel to the batts with a new PWM for the existing 12V panels.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
