brulaz
Oct 18, 2015Explorer
MrWizard wrote:
its about matching panel voltage when parallel
series panels must be identical "AMPS" so identical panels are used
parallel panels need matching "voltage for the MPPT parallel circuit input to work correctly
Been wondering about this. Some questions:
1) I know you want to match parallel panel voltage for best MPPT controller operation, but does it matter as much or at all for PWM?
2) For panels in series, you match amps otherwise the panel with the lowest amps (highest resistance?) limits the total current output? Or ...?
3) And that limitation for panels in series (2 above) is independent of whether you have a MPPT or PWM controller?
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
