JAXFL's avatar
JAXFL
Living in Florida's 48 hour FREEZE??
Living in Florida so don't winterze during the winter and have not again this year and now the ARTIC FREEZE is due tomorrow 19-25* for 48 hours. Besides turning on the furnace in the MH while plugged into the house or leaving for the Keys... what do I need to do today?
  • j-d's avatar
    j-d
    Explorer II
    Our gray and black tanks were dumped, so I drained the fresh water tank, low point drains and water heater. I need to go out and drain the inside and outside shower. If your heat is ducted into the tank areas, you should be good. Our waste tanks are under the coach, and the fresh tank is too, above the rear axle, so running heat won't help in our case.
    Would be interested in hearing what others are doing.
