MEXICOWANDERER
Apr 29, 2019Explorer
This is why I recommended BFL talk to Concorde.
By FAR the easiest way to query an AGM battery to see up is to fully charge the battery a week after you get it./// amps and volts twiddling to your heart's content.
later, down the line, repeat the tests then compare to brand new.
Example wait one hour before disconnecting a fully charged AGM but tweak the voltage up .5 volts for that one hour. Disconnect and take surface charge volt readings for the next 2 days. What do you see? Many spurious observances can be had with non standard testing. Gains in OBSERVED can be disqualified with a carbon pile load tester. AGAIN! Test when new compared with subsequent tests.
