beemerphile1
May 25, 2017Explorer
DutchmenSport wrote:
The danger of NOT draining the water heater and removing the lime build-up is because, if that lime builds up, and up, and up, and then it touches the electric heating element, it will burn out the heating element... even in your house.
The only difference in your house, the bottom (electric) heating element is usually 10-12 inches from the bottom of the tank. But it does happen that the lime builds up that high. Other than a leak, that is the reason why water heaters need to be replaced. Now if you have a gas water heater in your house, the burner has to transfer the heat through all that lime build up before the heat reaches the water.
That's why it's important to flush your house water heater once a year too, or at best, ever couple years. It helps flush out some of the build up, enabling your water heater to last longer. If you don't flush them out, the lime build up can add an extra 50 to 100 pounds of weight to the water heater. When trying to remove it for a new one, they are VERY heavy! (I know... been there ... done that!)
In an RV, the distance from the bottom of the tank to that heating element is not very far! Flush it out often! Once is builds up and sticks, it's near impossible to break free.
I'm not saying you are wrong but I don't understand how mineral deposits would burn out the heating element.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
