We just put a brand new lock on the Lance, and went to get into it yesterday and couldn't. I only locked the handle, not the deadbolt, but when you turn the key the handle doesn't release. Also you ...
Sometimes, when you install new key locks, you need to install it with the latch bolt and deadbolt extended. I have no clue why, maybe pressure on the assembly when you tighten screws.
Key both extended, 'locked' tongues out. Install it, then retract both, and shut door - keys should work properly. Try locking and unlocking several times before you shut the door and lock it.
