JKwockExplorerMay 28, 2017Long gray valve handleDoes anyone know if I can screw off my existing long gray handle valve and put it on the new one because I have to change my gray valve and it in the middle of the 5th wheel?
DutchmenSportExplorerMay 28, 2017There's two different kinds of slide valves. Depending upon which one is on your camper will determine how you replace it.Some have the handle connected directly to the slide valve. These handles are usually threaded and can just be screwed on and off.The other uses a cable. These just have be replaced.http://www.rvfamilytravel.com/ultimate-guide-rv-waste-water-tanks/
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
Related Contentt handle on valvesHandling Invalid HTML CodeDeisel handlingblack tank valve handle in or out means valve closedGrey and Black Dump Valve Handles
