Jonnygsx
Dec 12, 2013Explorer
westend wrote:
Isn't your present battery location between two propane tanks, underneath a hinged cover? If so, maybe you could stack an additional battery on a frame, over the existing battery. Alternatively, underneath in it's own battery box on a frame.
The present location is in front of the cover in the tongue area. The cover has a small cutout that jsut barely lets it clear the single battery mounted there. But it only clears a 12v battery, a 6v golf cart battery is to tall. To mount one battery inside the cover area I will need to bolt on some angle aluminum to the frame. It would be just as easy to bolt on a long piece so that a battery can be mounted on each side as a shorter piece for a battery on one side.
