RCMAN46
May 19, 2013Explorer
Once grease has got on a brake shoe it can not be cleaned off. The shoe has to be replaced. If it is used after cleaning it will not have the same braking effort that the other wheels have. It is recommended that all shoes be replaced at the same time for even braking on all 4.
If braking is not even one or more of the tires may be flat spotted or have excessive wear.
I inspect my brakes every two years and repack and replace the seals. No need for Easy Lube if you inspect brakes.
When my trailer was new I had brake problems and found grease on three of the four wheels from the factory. Even with a new trailer I would recommend inspecting the brakes and replacing the cheap factory grease seals before the first trip.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 14, 2026
