- Big_KatunaExplorer II
smkettner wrote:
http://www.corddepot.com/shop/generators/nema-14-50r-connector/ $35
Note the clamp connection
These are the ones I saw at an RV show. I'll save this link and try them next time.
I got the Progressive in. My only complaint is they use steel hardware. I'll replace the cover hardware with stainless. - pianotunaNomad IIIHi Green,
I had a Camco 30 amp male and female pair which has burn marks on it. I was plugged into a 15 amp circuit at the time. What would have happened at 30 amps? - Chris_BryantExplorer IIHave you ever installed one? Every replacement connector except the Progressive uses a simple screw to terminate the wire- it is a huge pita to get a #10 stranded wire all under that screw. The Progressive has a captive type termination- you stick the wire in a pocket and a set screw tightens against it- much, much better. The case is also not much larger than the molded. Plus, it's made in the USA.
- greenrvgreenExplorerHow come everyone's bashing the Camco plugs? The yellow ones with handles? I love those things--to my eye they seem much sturdier than the progressives.
- Big_KatunaExplorer III said Coleman for the recep. Its Cooper and not too bad, better than the Camco.
pianotuna wrote:
Hi,
May I ask you to post a link to this item? Thanks in advance.Big Katuna wrote:
On edit, I cant find their plug. Found the recep easy enough.
Amazon Prime $20.
clicky
I rounded down.
The Hubbel is $61. I think not. - Dick_BExplorerI recently bought a new cord with a right angle connection at the camper end to avoid the strain which was pulling the cable out of the connector. (Probably not my best work to install the connector)
- Hubbell makes a premium 50a plug.
http://stayonline.com/detail.aspx?id=9005
I would probably end up with Progressive for the female end. Maybe both to match.
http://www.progressiveindustries.net/#!rv-14-50r-connector/c1c1d - westendExplorerDo you have a power inlet or are you making up an extension cord?
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 13, 2025
