obscenic
Nov 12, 2014Explorer
enblethen wrote:
The PD5500 does not have a 12 volt DC section
WFCO 8930/50
Need to remember that there is specialty type four pole breakers. You could get something like a 50/30 double pole breaker where the main would be back fed into the fifty and then your heater would be fed off the 30. This is just an example as a 30 would be too large. You could get something like a 30/20
If a combined unit such as these will not meet what you need then you are going to need to construct a make shift unit.
I've conceded to getting a separate 12v unit. Tech support at wfco have NO idea what they're talking about, and incredibly poor reading comprehension and writing skills. I've basically given up on wfco. They may work, but based on the placement of the main breaker on the one you posted, there's a 95% chance each half on either side are only serviced by one busbar. Is other words no chance of using a 240v breaker.
