GordonThree
Oct 09, 2014Explorer
SuaveGato wrote:
Hello,
Due to some good advice from this forum THANK YOU, I am looking into replacing my existing "converter" (InteliPower 9100 #PD9140A). From what I understand, the converter converts AC shore power to 12 VDC and assumedly the generator AC power too? (seems odd/wasteful though to have the Generator make DC, invert it to AC, the convert it back to DC? But I digress...) I also understand that the converter charges the onboard batteries ( (2) 12 volt deep cycle marine/RV) but not very well and can easily boil them off?
So, assuming the above, it has been recommended to me to replace my converter with a newer more modern one that will not only convert my AC to DC but also has vastly superior battery charging system. (with de-sulfating mode) And I "think" they also make an all in one Converter/Inverter/battery charger? Is that true and if so, what would be some recommended makes and models for my camper? I don't need a big inverter, maybe 500 watts? I have a generator for when I need "big power" but I need to plug in a CPAP machine all night that runs on AC and maybe some other misc. things like TV, DVR & DISH receiver, laptop etc.
Thanks for any help and info.
Just my 2 cents, my trailer's converter has been unhooked for two years, and my Inverter/Charger from Magnum has been doing fine. The "charger" portion of the inverter replaces the role the converter played, and it provides a lot more DC power too. I think my WFCO was 30 amp DC output, where as the Magnum is 125 amp DC output.
I set the Magnum up in "UPS mode" so if shore power goes out, or it's time to go home and I unplug, it switches to battery so fast none of my AC devices notice, even the microwave or air-con (2800 watt inverter with 4000 watt surge)
It wasn't cheap, and I like to make things complicated, so I rewired pretty much the entire AC panel in my trailer installing it, but it's working great.
I'm not sure how much room you have for batteries - that's the Achilles heal of any inverter system. I have four group 31 200 amp-hour AGM batteries, and I run everything I want to for two or three days (fridge on propane)... tv, laptop(s), waffle maker, hot water kettle, microwave, fans, bedside lights (are ac in my coach), etc.
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
