SuaveGato's avatar
SuaveGato
Looking for advice: converter/inverter brands, models etc.?
Hello,
Due to some good advice from this forum THANK YOU, I am looking into replacing my existing "converter" (InteliPower 9100 #PD9140A). From what I understand, the converter converts AC shore power to 12 VDC and assumedly the generator AC power too? (seems odd/wasteful though to have the Generator make DC, invert it to AC, the convert it back to DC? But I digress...) I also understand that the converter charges the onboard batteries ( (2) 12 volt deep cycle marine/RV) but not very well and can easily boil them off?
So, assuming the above, it has been recommended to me to replace my converter with a newer more modern one that will not only convert my AC to DC but also has vastly superior battery charging system. (with de-sulfating mode) And I "think" they also make an all in one Converter/Inverter/battery charger? Is that true and if so, what would be some recommended makes and models for my camper? I don't need a big inverter, maybe 500 watts? I have a generator for when I need "big power" but I need to plug in a CPAP machine all night that runs on AC and maybe some other misc. things like TV, DVR & DISH receiver, laptop etc.
Thanks for any help and info.
  • P.S. if there is one that is also a solar control module in addition to converter/inverter/battery charger that would be even better as I need one of those too!
  • A little off subject, but does your CPAP operate on DC also ? & do you use a humidifier ?
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
