Gjac
Oct 23, 2013Explorer III
mchero wrote:When this happened to mine I glued the broken piece back with JB weld then cut a piece of tubing and slid it over the cracked piece and glued it in place. Once the knob is installed you can't see the repair.
If any body has the same stove be CAREFUL!!!!
If you break the oven knob you won't find a PROPER replacement.
Perhaps the lubrication dry's up & makes the valve hard to turn thus cracking the knob.
I'll have to try & lube mine.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
