Almot
Apr 15, 2016Explorer III
smkettner wrote:johnm1 wrote:What do you have now and how does it work for you?
I'm trying to figure out how much battery I "need" and then size the solar to recharge them.
ALL solar or generator backup?
Here goes the spreadsheet. Why calculating when you can ask at Rv.net :)...
I agree, not enough input data provided. Generator for high-current loads changes the picture. N8GS spreadsheet gives a good ballpark figure for all-solar system.
Today panels are cheap, and the cheapest per watt are the biggest ones, over 220W each. The cost of controller jumps abruptly when you cross over 300-400W because at this point you need more expensive MPPT controller. Then it's pretty much proportional to panel wattage.
Get as much panel wattage as you can, unless you are a minimalist and can live without MW and other high-current loads (and then you could stay within 300W range and low-cost PWM controller).
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: May 01, 2026
