Sam_Spade
Jan 11, 2016Explorer
RJsfishin wrote:
Quote:
I'd pay the extra money not to worry about gassing & filling with water...
AGM is not going to fix that. You need a new PD wizard converter.
Yes it WILL.....in most "normal" cases.
A conventional flooded cell battery will gas if the charging voltage is just a tiny bit high and/or during periods of fast charging. Over a long period of time, that adds up to water shortage. A really good controller can help but it can't defeat the basic chemical reactions.
An AGM will not gas at all under "normal" conditions; they are in fact sealed and can't lose gasses until the internal pressure approaches the explosion point.....which should only happen with a nasty internal short or a massive overcharge.
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 08, 2026
