Sam_Spade
Jan 11, 2016Explorer
KATOOM wrote:
Solar in the future is possible but I cant say for sure.
As I mentioned before, I thought two 6 volts offered that advantage over two 12 volts.
That's true but only in generalities. One could create a parallel 12 V bank that might perform good but it is easier to do two 6's in series that do a good job......and most times cheaper and more reliable. When you get right down to it, a 12 V battery really is two 6 volters in series in the same case.
In addition to your possible solar panel, have you considered reducing your consumption farther by installing things like LED lighting ??
P.S. I think it is more rude to NOT search than it is to suggest a search after posting a repeated question. Opinions vary but if EVERYONE followed your logic things would get out of hand rather quickly.
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 08, 2026
