Acampingwewillg
Aug 13, 2018Explorer II
Lots to be considered but if I were doing it and going to the trouble of renting a Ditch witch, I'd go with 1" PVC in case you ever want to up grade. Non GFI circuits need to be 18" deep(I'm sure that changes by location) and I would definitely use stranded wire by the roll. You can get the wire cut to size after installing you conduit. Good Luck with your project.
