Rettrooper
Jan 19, 2014Explorer
dougrainer wrote:Rettrooper wrote:vic46 wrote:
http://www.dinosaurelectronics.com/
X2
I had the same Norcold N621, just not the same problem as you. I did the swap with the dinosaur board, it has run like brand new. Don't look back or play with the OEM board. You'll be very happy with the dino board.
BTW the swap out of the board is very easy to do, requiring no special tools or techniques!
What difference would the Dino board make on operation???????? Doug
Doug
The Dino board swap eliminates the problems that the OEM board produced. In my case, my display would read: "FA" and then shut down and not run on gas at all. It would however continue to run on electricity with either the genset or shore power. Once I replaced the OEM board with the Dino board, it has been flawless, both on gas and electric. Dino board was replaced 6 years ago.
Well worth this minor investment.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
