Wolfe's avatar
Wolfe
Looks like I need a new main board for Norcold N621
I was wondering if anyone tests these board before I buy one.
It would be a nice service seeing that you can't return electrical parts.
Anyway, the refridge was working fine, it now has no display at all, I did all the troubleshooting and all voltages are there so it looks like I will be getting a Dinosaur board.
  • Rettrooper wrote:
    dougrainer wrote:
    Rettrooper wrote:
    vic46 wrote:
    http://www.dinosaurelectronics.com/
    X2
    I had the same Norcold N621, just not the same problem as you. I did the swap with the dinosaur board, it has run like brand new. Don't look back or play with the OEM board. You'll be very happy with the dino board.
    BTW the swap out of the board is very easy to do, requiring no special tools or techniques!
    What difference would the Dino board make on operation???????? Doug
    Doug
    The Dino board swap eliminates the problems that the OEM board produced. In my case, my display would read: "FA" and then shut down and not run on gas at all. It would however continue to run on electricity with either the genset or shore power. Once I replaced the OEM board with the Dino board, it has been flawless, both on gas and electric. Dino board was replaced 6 years ago.
    Well worth this minor investment.
    MY point being, if you had replaced with a Norcold your problem would have been fixed also. Doug
Having RV issues? Connect with others who have been in your shoes.24,191 PostsLatest Activity: Jan 19, 2025
