D_E_Bishop
May 03, 2018Explorer
Chum lee wrote:
Since you have a choice when you buy the replacement bolt, whatever size you decide, I would suggest that you buy a grade 8 bolt instead of a softer bolt since it is loaded in shear and subject to rotational wear. Common hardware fasteners aren't the best choice. Reaming/drilling out the existing holes to a consistent size/clearance would also be a plus if you want the repair to last and rotate cleanly.
Chum lee
Isn't that pretty much what I said in describing the possible ways of doing it. I believe Kwikee used mild steel in building the steps and the rivets are mild steel.
