down home wrote:
I emailed Roadmaster and got no response.
The Sterling Tow bar where it plugs into the receiver on the Motorhome has an 1/8" to 1/4" clearance top and bottom. It rotates up and down on the pin. 4500 lbs of towd slams it up or down on stopping or starting or braking....and that is not a good thing.
Campign World installed the tow bar years ago.
I have tried to put small rubber washers on top and bottom but of course they didn't stay.
I don't think this was intentionally designed to do this.
Any ideas on how to fix this before it destroys the receiver?
Does it fit more tightly on the sides? If not, and you have a 1/4" play top and bottom and the sides. You don't mention what type or year of motorhome, if you have had it for a while or it's new to you........I suspect you may have a 2" insert in a 2 1/2" receiver???? It's highly unusual that a 2" draw bar have that much play in a 2" receiver. There is some movement in all set ups but I have never seen 1/8 to 1/4 inch play.
