enblethen
Jan 14, 2015Nomad
There is no direct link between the 12 volt system and the 120 volt AC system unless everything is run through an inverter. Not likely!
You are saying inverter, do you mean inverter or converter?
A converter changes 120 volt AC to 12 volts DC.
The inverter changes 12 volts DC to 120 volts AC.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
