skipnchar
May 20, 2013Explorer
Leaks do0n't HAVE to be inside the RV. Check around the water heater pop off valve and the drain plug for signs of seepage. It could also be leaking out the pressure water connection if the check valve is not holding well there. Another outside leak is the dog shower and even better hidden, the low point drains could be leaking.
Doesn't HAVE to be a leak inside of ourside to loose pressure because it COULD be bleeding the pressure through the water pump into the non pressurized water tank. They can be time consuming to check and locate the problems but I'd recommend you begin with the items that don't cost anything or can easily be seen and work your way up to the more costly items.
Good luck / Skip
Good luck / Skip
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
