j-d wrote:
Just found that there's another KiB Disconnect Relay, and I think it might be the one on our Jayco Class C. Here's that wiring diagram:
Notice it only uses two wires and it's called a "Pulsing" relay. Pulse once and it changes from On to Off or Off to On. The Intellitec, and maybe that other KiB that I posted above, reverse the polarity going to those two small terminals. When "I" is hot, it goes into Use/On. When "S" is hot, it goes into Store/Off.
Please look at the Relay in your pix, and post the Number stamped into the plastic, below the molded "KiB" Logo.
Mine has KiB LR9806 stamped on it. When I went on Amazon I typed in that number and it pulled up the Intellitic relay 0050000 ??? It looks just like the one in the pic.
