brianseay1's avatar
brianseay1
Loss of electricity
Just got home last night from a trip. Parked the rig everything was fine.Left the fridge running and water heater was on.Went out this morning and the wife took out the rear slide to get stuff out and brought the slide back in. I go to put the rig in the garage and to plug it in and now I have power to the Inverter panel but nothing else. No lights but the microwave does come on. I have checked the breakers and fuses everything looks good. I have tried to reset the battery disconnect but get nothing. Entry lights do not come on. Steps are working. Fridge will not come on. what do I need to be looking for ??? I checked the batteries and they are fully charged. I am lost, any help is appreciated.
  • ok, I cannot find any other GFCI outlets.I have one regular outlet in my basement.I have looked at fuses and double checked my breakers. Inverter panel show i have power to it, but the coach control panel has nothing. Could the battery disconnect switch went bad all of a sudden? everything was fine last night.
  • brianseay1 wrote:
    TakingThe5th wrote:
    donn0128 wrote:
    Get out your volt meter and start checking. Probably a GFCI problem
    X2. Start by resetting the GFCI. Might be an easy fix.
    I only have two GFCI outlets that I know of, unless I am overlooking one. I have one in the bathroom and the other in the kitchen.
    Quite frequently there is a GFCI located outside, perhaps in the basement.
  • Checked the GFCI outlets, both have the green lights on and power. The house batteries have 13.4 volts. I the have the green light on the AC in, Inverter and Float indicators on the inverter panel.
  • What is battery voltage (house battery). If too low, voltage can be too low to close the disconnect relay.
  • Get out your volt meter and start checking. Probably a GFCI problem
Having RV issues? Connect with others who have been in your shoes.24,301 PostsLatest Activity: Apr 17, 2023
