base1957's avatar
base1957
loss power 96 Winnebago vectra gmc
Well...it's my year
Driving down the road...engine coughs once or twice and boom no engine, now brakes, no power steering.....will turn over but sounds like timing is off so bad it won't start at all...gotta get er towed.any thought s other than getting another rv...
  • If the timing actually sounds like it's off then it likely skipped or broke the timing chain.
    Fortunately not a huge job but in a MH it will be hard to get to.
  • Borrow a code ready from O'Reilly auto parts or auto zone.
    Sounds like a crankshaft or cam shaft position sensor.
    Test it first
  • Not to be a bearer of bad news but I think GM used to use phenolic timing gear sets that were known to fail.
  • Let a mechanic check it before you hit the panic button. Maybe it's something relatively simple and inexpensive.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
