steved28
Apr 10, 2019Explorer
It seems removing the OEM fan was the point you lost your ground. So that would be where I would find the "new" ground. As YC 1 suggested, most likely that entire circuit receives its ground from the fan mount. If you ground the negative to the fan, do your lights work? I assume they all share the same ground?
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
