Chris_Bryant
Apr 10, 2019Explorer II
You are measuring voltage on the ground because the ground is picking up voltage from a light that’s on. Hook one side of a light to a battery and you will assure 12 volts on the open lead. The ground is hot because it isn’t hooked to ground.
As others he sai, try installing the vent fan and go from there, which would be going back through the circuit, finding the last item that works.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
